Old 07-22-2008, 10:08 PM
In-filling skip sheathing
I've never seen this before and I'm a bit skeptical. Have you guys ever seen this? In particular I don't really like the gaps left behind. Strangely enough, I looked really hard and couldn't find and fasteners in the gaps.
I realize while looking through my pictures that I didn't snap one of this exact problem. The ones below are of a broken rafter and a piece or romex tacked tightly across the attic access hatch.... hopefully, you'll see what I'm talking about.
fyi... the current roof is a single layer comp.
Old 07-22-2008, 10:36 PM
Brandon Whitmore Brandon Whitmore is offline
Re: In-filling skip sheathing
I wonder if my buyer's walked. Just Kidding. I did one like that 2 weeks ago, but there were up to half inch gaps between the boards. It would have been so much better/ easier to just skin over the skip sheathing with a panel sheathing. I just told my buyer's that it was wrong, because some of the nails were hitting in the joints (not hitting sheathing). In your case, I would say that it is unconventional, and that you can not predict how well this system will function in the future. You could always fall back on the manufacturers sheathing requirements as well.
Old 07-23-2008, 10:29 AM
Gunnar Alquist's Avatar
Matt,
I have only seen that a couple of times. Probably because it takes too long and plywood or waferboard is quicker. I don't have a real problem with that except that it does not provide the shear value that plywood or OSB does.
What is the circumference of a moose?
Old 07-23-2008, 01:09 PM
Steve Lowery Steve Lowery is offline
I did a job like that several years ago. It was pretty simple. The house was a '60's custom w/ shakes. The contractor had put 1x6's & used a 1x4 for spacing them. With shrinkage over the years, new 1x4's fit nicely with only an occaisonal rip needed. Renailed & replaced (where needed) existing. It was way cheaper & less time as well. Unconsequential gaps.Than God for nail guns.
Old 07-23-2008, 07:43 PM
Thanks guys.... I had about the same feeling. It was odd but seemed to be working okay. I basically said it appears to be doing what it's suppose to be at this time. A roofer or shingle manufactuer might be able to tell you more if you're interested.
Similar Threads
2 Layers of sheathing?? Paul Kondzich Roofing System: Home Inspection and Commercial Inspection 1 07-15-2008 10:14 PM
Thermo-ply sheathing Eric Shuman Building Envelope: Home Inspection and Commercial Inspection 7 10-28-2007 11:26 AM
Roof sheathing william siegel Roofing System: Home Inspection and Commercial Inspection 3 10-09-2007 02:38 PM
Flue against roof sheathing Ken Milton Introductions By New Members 6 07-29-2007 09:11 PM
Roof Sheathing Repair? Larry Vance Roofing System: Home Inspection and Commercial Inspection 1 07-19-2007 08:38 AM
vB.Sponsors
Ad Management by RedTyger
