Old 05-07-2007, 08:40 PM
Eric Shuman Eric Shuman is offline
Jack flashing shingles at edges.
Does anyone else call out that the side of jack flashings should be covered by shingles at least down past where the hole or opening of the pentration is? I have seen wind driven rains blow under the edges of the flashing and come in the hole.
If you look at the vent in the background, the shingles come down farther than the vent in the foreground.
Thanks,
Eric
Old 05-07-2007, 09:32 PM
wayne soper's Avatar
Re: Jack flashing shingles at edges.
So which vent is in the wrong position. The shingles lie where they lie according to initial layout. One lies at center and one above center. So you want to change the reveal on that row or what. I understand your thought but in reality it would occur rarely as the plumbers and roofers never talk.
Can you imagine a plumber laying out the shingle pattern? That would be a good one! Or the roofer setting the waste lines? Might be even better.
Old 05-07-2007, 10:02 PM
So what you are saying is that the shingles cannot be cut out to fit the vent as it appears they had to do at the vent in the back ground?
Old 05-07-2007, 10:08 PM
Tim Moreira's Avatar
Tim Moreira Tim Moreira is offline
I disagree with Wayne on this one.
The photo in the foreground looks to me like they could have and should have had another row of shingles added across the bottom of the vent.
Maybe it's just the way I'm looking at it.
Also, maybe just he angle of the photo, but is that vent the correct one for that pitch of roof? Looks a little angled.
Old 05-08-2007, 06:27 AM
Rick Cantrell Rick Cantrell is offline
That is not right. The shingles should be on top of the flashing.
Rick Cantrell
  #6 (permalink)
Old 05-08-2007, 06:31 AM
OK, now I see it.It does line up and should be lapped there. Sorry. I should have looker closer.
Similar Threads
Jack of ALL trades Darren Miller Associations, Ethics, Standards, Licensing, Legislation:Home Inspectors & Commercial Inspectors 12 04-29-2007 11:51 AM
Asphalt comp shingles Jeff Eastman Roofing System: Home Inspection and Commercial Inspection 6 04-23-2007 05:48 PM
Roof flashing william siegel Roofing System: Home Inspection and Commercial Inspection 2 04-18-2007 03:50 PM
Chimney Flashing Warren Alderman Attic Areas: Home Inspection and Commercial Inspection 3 04-06-2007 09:43 AM
Roof Jack w/ Neoprene Boot At B Vent Bruce Breedlove Roofing System: Home Inspection and Commercial Inspection 6 04-03-2007 02:14 PM
vB.Sponsors
Ad Management by RedTyger
