Thread: Sub Panel
05-26-2007, 04:43 AM #1
Sub Panel
What year did nec. mandate four wires for a sub panel, residential wiring
05-26-2007, 05:01 AM #2
Re: Sub Panel
Don't have answer for your question but I'd like to clarify. Perhaps it would be better to say four conductors. In our area most wiring is in metal conduit which serves as a conductor. So for subpanel, three wires in conduit would suffice.
05-26-2007, 05:15 AM #3
Re: Sub Panel
Hmmm ... I'm having trouble finding the term "subpanel" or "sub panel" in my 2002 NEC ...
Maybe Jerry P. knows something about this ...
05-26-2007, 05:54 AM #4
Re: Sub Panel
We have a trouble maker here.
05-26-2007, 06:01 AM #5
Re: Sub Panel
I resemble that remark.
05-26-2007, 06:36 AM #6
Re: Sub Panel
make the bad man go away....
05-26-2007, 06:49 AM #7
Re: Sub Panel
Evil. Pure evil.
- Paul Fix
05-26-2007, 06:54 AM #8
Re: Sub Panel
I've only seen one "sub panel", it was in a "submarine", so it *was* a "sub panel".
The question, I think, is when did the NEC require the neutral to be bonded 'only at' the "service equipment".
Without going back and checking through my old codes, I'm guessing that it was 'aways' that way, just not clearly stated as such. I' think I recall that the wording was clarified in the 1920s, with continued clarification in subsequent codes as needed, ending up with the current wording.
Regardless, though, of when the code clarified the wording, it is not safe and should be written up when found - however old the house is.
05-26-2007, 07:13 AM #9
Re: Sub Panel
Okay, who are you and what have you done with Jerry? If you hurt him, we'll hunt you done like dogs.
- Paul Fix
