Results 1 to 18 of 18
Thread: Ferrous Ochre
03-28-2009, 08:23 AM #1
Ferrous Ochre
Hi every one,
I have been reading posts on the website for a while and I appreciate the valuable time and info put and discussed here.
There is one subject that I could not find any post discussing it which is FERROUS OCHRE or FERROUS OCHER (Mineral deposits found in the French drain system).
If you know of one please let me know or perhaps this post can be the one.
03-28-2009, 08:46 AM #2
Re: Ferrous Ochre
03-28-2009, 09:50 AM #3
Re: Ferrous Ochre
Thank you Scott for the reply.
Actually the photo you have seen is taken from somewhere elese with an extreme situation.
The photo I have taken from the inspection site is attached here.
The concerns are from the following facts:
- This house is situated in an area known to have Iron Oxide (Ferrous Ocher in Latin)
- I have read an article about (Contagious Ferrous Ocher ??) where it grows into neighboring units.
- There are different forms of Iron Oxide that have different colors other than Orange (RED)
- The red coloration here is at the top and below it is a black color sludge.
So after all that :
Is it possible that this house soil is just getting contaminated or I should not worry about it or shall I recommend a LAB test.
03-28-2009, 02:06 PM #4
Re: Ferrous Ochre
To put yourself at ease, there is no harm done in testing the soil and water to verify what it is which is contaminating it.
Better to know there is no problem and not have to worry, or, know there is a problem and have to decide what your next options are, than to not know and be concerned about it every time you think about it.
03-28-2009, 04:34 PM #5
Re: Ferrous Ochre
As Mr Jerry said there is no harm testing the water. I have seen where overhead sewer systems have had cracks in the line and was leaching raw sewerage in to the French drain system causing the black sludge in a sump pump pit.
Last edited by Ron Hasil; 03-28-2009 at 07:23 PM. Reason: Had to not call Mr Jerry an ass. So fixed the typo
03-28-2009, 06:40 PM #6
Re: Ferrous Ochre
Ron,
Hoping that was a "typo" ...
03-28-2009, 07:22 PM #7
Re: Ferrous Ochre
03-28-2009, 07:31 PM #8
Re: Ferrous Ochre
Thanks guys, I believe I will indicate the possibility of Ferrous Ocher and advise him to get a lab test.
I hope we can find more detailed literature about this matter. Thanks again
03-28-2009, 07:43 PM #9
Re: Ferrous Ochre
Mghazal here is a link to University of Flordia that I have found a good read about ochre. I hope it helps you as well. CIR671/AE026: Iron Ochre And Related Sludge Deposits In Subsurface Drain Lines
03-28-2009, 08:40 PM #10
Re: Ferrous Ochre
Ron,
Thank you for posting that, it is always good to read good and useful information applicable to the question at hand.
Thank you.
03-29-2009, 10:29 AM #11
Re: Ferrous Ochre
As usual great stuff, great infi.
Thanks a million guys.
03-29-2009, 10:30 AM #12
Re: Ferrous Ochre
Spelling mistake corrected:
As usual great stuff, great info
03-29-2009, 12:22 PM #13
Re: Ferrous Ochre
The black film deposits sticking to the PVC looks to be biofilm.
Sulfur reducing bacteria - black-ness of the material likely mostly iron sulfide. Manganese and Nitrates may also be present.
If you're not detecting a sulfur odor, perhaps iron reducing bacteria.
Not unlike what we'd expect to find in a septic drain field or where a sanitary sewer has a breach, or a contaiminated well.
Bacterial analysis caution against untrained acquiring samples some pathogens can make you very ill.
This article mentions some potential pathogens (but not all).
Biofilm Remediation - Feature Articles - National Driller____
03-29-2009, 12:53 PM #14
Re: Ferrous Ochre
03-29-2009, 05:04 PM #15
Re: Ferrous Ochre
Actually this house is situated in a rural area and does have a septic tank adjacent to it.
What I understand here is that there is a possibility that the septic tank is leaching near the French drains and that is why we see those black sludge deposits?
03-29-2009, 06:02 PM #16
03-29-2009, 07:00 PM #17
03-30-2009, 09:33 AM #18
Re: Ferrous Ochre
Mghazal,
All the information you need (en français seulement) at link below:
Le Réseau de Protection du Consommateur
Click on *Association* on top of page, and choose*Association des consommateurs pour la qualité dans la construction*, under *Dossiers*, click on *Ocre ferreuse*.
Hope this helps,
That should tell you.
LOL
