Thread: TPR Question
06-28-2009, 06:19 AM #1
06-28-2009, 06:55 AM #2
Re: TPR Question
06-28-2009, 07:03 AM #3
Re: TPR Question
Is that foam insulation on the water pipes all the way next to the draft hood?
How is B-vent attached to hood?
As JP, that TPR all wrong.
06-28-2009, 07:30 AM #4
Re: TPR Question
The T&P valve is all wrong. Can not tie into the Vent system for the building drains and not allowed to use PVC. Also where is the vacuum relief valve? Any time you have a water heater installed with any fixtures below it you need a vacuum relief valve installed on the cold water side after the shut off valve.
06-28-2009, 09:53 PM #5
Re: TPR Question
What about the duct tape (which is combustible) being that close to the draft hood? Is there a base to support the idea that that is wrong as well? I mean a base other than my own imagination.
06-29-2009, 06:00 AM #6
Re: TPR Question
John,
The duct tape is on the foam which Bob H. pointed out.
The best answer is "It's all wrong.", if one needs more detail then we could make a list of what is included in "all wrong".
