Results 1 to 25 of 25
Thread: What is it
    Paul Johnston's Avatar
    Paul Johnston Guest
    Default What is it
    Does anyone know what this is? I think it is some kind of alarm. It sits on top of a septic tank and has a 1/2" pipe in the tank and 120V.
    Paul
    Default Re: What is it
    Air pump for an aerobic system.
    Paul Johnston Guest
    Thanks Jim. Here is the leach field. It is made of 2 10' pieces of pvc with kerfs cut in it and just runs down the mountain. No Caps and this is the septic system. The leach line is 10 feet from the tank. Note the erosion already.
    I hope they at least have a method of adding a disinfectant.
    Hmmmm
    Dumping sewer water down the side of a mountain............
    Can you even do that with chlorine tabs killing bacteria even in the middle of no where down the side of a mountain???? At least the Chlorine tabs in the line will kill the stink and bacteria a bit but still, just dumping it down the hill
    I guess, why not. They spray it through sprinklers everywhere else.
    Paul Johnston Guest
    What chlorine tablets? They don't even have electric for the air pump.
    Things are crazy here but cost top dollar.
    Again
    Further evidence that "pure mountain spring water" ain't so "pure" and not quite so "tasty" in many places. No wonder there is a lot of fecal matter in bottle water taken from natural springs (which is not treated water, just bottled from the springs).
    Paul Johnston Guest
    You are right Jery. It amazes me how many people think bottled water has been treated. They look at you like you lied to them.
    Quote Originally Posted by Paul Johnston View Post
    Absolutely right!
    There was a report on bottled water on some of the TV stations in South Florida a number of years back about bottled "natural spring" water and "reverse osmosis" water being bottled and sold as "natural water".
    EVERY SINGLE BOTTLE of "natural spring water" was so full of contaminates, with the largest percentage being fecal matter, that it would never have been allowed to be sold through water departments and piped into your homes, yet people spend mucho more money for contaminated "natural spring water" and pooh paw about it being untreated as though treatment is not necessary.
    The "natural water" filtered through reverse osmosis was simply municipal water with further filtration and was the most healthy water available for drinking and cooking, but it did not have the 'natural spring water" label so no one wanted it.
    Hmmmm
    TM: GWB set the example. These guys were just imitating their leader.
    You did not just sat that....Did you ??????
    I think GWB ran your toes over. He appears to be responcible for everything. I bet whrn you get constipated it is his fault as well !!!!!!!!
    My guess it is a highwater alarm.
    TM: Get a grip, Ted. I am just attempting to get a rise out of Left Coast Biker Boy and his bitch.
    I know but I do think you and GWB might have had a little , lets say, Quarrel I think he must have thrown you over for someone else. What do they say about a lovers scorn
    TM: If you knew as much about that piece of work as I do, you would feel the same way. He has not been out of office quite long enough for the floodgates of bad press to open. Wait a year and see what you think by then.
    ...I bet whrn you get constipated it is his fault as well !!!!!!!!
    Actually, he gave me diarrhea.
    JA: He sort of has a similar effect on me, but it's more like motion sickness combined with a moonshine hangover topped off with gas.
    HiBlow HP80-013A and HP40A Septic Air Pumps with Attached Alarm
    HP80-013A and HP40A Air Pumps with Alarm mounted on the side to be used without housing or platform. Air pump is UL listed and weatherproof. Simply plug in and it's ready to go. The alarm has a switch for mute, run, and test.
    HiBlow HP Septic Air Pump Aerators FREE SHIPPING
    Not the exact match, but pretty close.
    Ron Bibler's Avatar
    Ron Bibler Guest
    Aaron AKA ( Bagdad Bob ).
    * it appears someone has Peed in your Cheerios.
    You have come back for more Likes it soggy
    Paul Johnston Guest
    Thanks Jim,
    That is exactly what they have but it does not work very well with out power.
    Paul
    gary gramling's Avatar
    gary gramling Guest
    Does that pump force it down the mountain faster through that hi tech leaching system?
    Inspector 3500's Avatar
    Inspector 3500 Guest
    Paul,
    I bet even in Costa Rica that septic system is installed wrong. When the health officials find it the owner will face large fines and be required to install it correctly. Not having 120v to it is the lest of the problems.
    Paul Johnston Guest
    What health inspectors?
    This place is like the wild wild west.
    Must be tough inspecting. You never get an easy one.
    Paul Johnston Guest
    It is hard because you have to weigh the important things and just try to inform the buyer what he/she not getting, that they are accustom to in the North. Vents in plumbing are non existing in 99% of the homes and they use so many traps. Outside the house the toilet has a 4" trap, sinks and showers are double trapped (underground). Then you see signs in most baths do not throw paper in the toilet. Wonder why. When I am involved with new construction it is like pulling teeth to get one vent stack installed much less 2-3. Everyday is a new learning experience or a new WOW factor.
