		Thread: water heater TPR arrangement
	08-24-2009, 03:03 PM #1 water heater TPR arrangement water heater TPR arrangementthe building official told the builder he could do it this way or so it was stated.
 This has a solar heater on the roof with a recirculator. I was not sure if the tpr drain line could be t'd off with a return or supply?
	08-24-2009, 03:31 PM #2 Re: water heater TPR arrangement Re: water heater TPR arrangementIt can be done like that if they used the right T&P relief valve-- they need the longer style-- it has to extend into the top 6" of the tank I believe.
 The above info. is from what I have learned here, and is based on memory--- I can't say I've ever seen it done that way.
	08-24-2009, 04:06 PM #3 Re: water heater TPR arrangement Re: water heater TPR arrangementHey Brandon...
 You should check these fittings. some of them have a stamp on the side of them stating cold water only.
	08-24-2009, 05:09 PM #4 Re: water heater TPR arrangement Re: water heater TPR arrangementCorrect ... as long as the T&P has the extra long probe, usually designated by and XL instead of just an L, for example: 100XL, 1L, 1XL, 40L, 40XL, etc. ( Watts: Temperature and Pressure Relief Valves | Water Safety & Flow Control ).
 Also note that there appears to be a heat trap fitting in the two solar heater lines but NOT in the hot out, which is where a hot heat trap is needed.
	08-24-2009, 05:29 PM #5 Re: water heater TPR arrangement Re: water heater TPR arrangementgood stuff, thanks
	08-24-2009, 05:31 PM #6 Re: water heater TPR arrangement Re: water heater TPR arrangement
	08-24-2009, 06:01 PM #7 Re: water heater TPR arrangement
		Hi Ron,Hey Brandon... Re: water heater TPR arrangement
 Good memory.....
 http://www.inspectionnews.net/home_i...ater-only.html
	08-24-2009, 07:06 PM #8 Re: water heater TPR arrangement Re: water heater TPR arrangementThat's those transition fittings I keep mentioning since that thread came up and that information was posted.
 What you are looking at are "adapters" to "adapter" from a slip joint to a threaded joint, not "transitions" which "transition" from one material to another.
