Thread: Skylights
    Corpus Christi, TX
    Default Skylights
    Always some method I haven't seen. These were on a 9 years old house. There is no evidence of any historical leaking. If I had seen this on a new construction, I would bet money on it leaking. It appears to be nothing more than than some form of Plexiglas inserted under the shingles. There is no frame and you can see the top of the Sheetrock in the pix.
    Any comments? I haven't emailed the report yet.
    - Paul Fix
    Richard Rushing's Avatar
    Richard Rushing Guest
    Default Re: Skylights
    This may be wordy, but it is something that I would state...
    ___________________________________________
    This home has non-standard type skylights installed at two locations. A visual/ non-destructive type inspection was conducted, at which time, I did not observe any evidence of moisture staining or previous leaks.
    However, the servicability and service life of this non-standard product, and the means by which it is installed, cannot be predicted or physically inspected for proper installation. My visual inspection identified the following concerns:
    • No visible/ verifiable means of determining if the insert is flashed properly without physically removing the shingles around it. Doing so (shingle removal) is beyond the scope of this inspection and is not in accordance with the TREC Standards of Practice for inspectors.
    • Visibility to the sheetrock around the framed sections is a real concern with possible condensation build-up (not uncommon on skylight materials) which could eventually wick into the edges of the drywall product. Once introduced, any condensation could grow into other undesirable conditions.
    • Future repairs or replacements to a non-standard item will usually require further modifying the roof opening, which can be both costly and problematic.
    My recommendation: is for the buyers to condition the 'Amendment' for purchase, an item to include purchase receipts and any installation receipts, with warranties that may be transferable from seller to buyer.
    Richard
    David Banks's Avatar
    David Banks Guest
    Now thats good Richard.
    Corpus Christi, TX
    Thank you for your response. It is similar to what I wound up sending. I may send an ammended report tomorrow.
    - Paul Fix
    They used to make skylights like that many years ago. I used to install them back then too.
    Never had a problem with leaks either.
    Now, though, most skylights are curb mount types.
    Before referring to them as "non-standard", I would simply state that curb mount skylights are less prone to leaking than non-curb (curbless, we called them) skylights - HOWEVER - also remind them that ALL skylights are prone to leak.
    These ( Skylights by CeeFlow, Inc. - Skylights and Custom Projects - Specifications ) are not the ones from years ago, but they are still "curbless" skylights.
    There are also round skylights, with and without curbs.
