Thread: Vinyl Fascia
04-30-2010, 02:43 AM #1
Vinyl Fascia
Is it acceptable to use vinyl as a fascia? I have not seen it used before and when I came across some it was nailed in place and bowing.
04-30-2010, 06:36 AM #2
Re: Vinyl Fascia
04-30-2010, 12:30 PM #3
Re: Vinyl Fascia
Here are a couple of pictures.
04-30-2010, 12:32 PM #4
Re: Vinyl Fascia
Jon
It is allowed to be used, but not allowed to be nailed.
04-30-2010, 12:41 PM #5
Re: Vinyl Fascia
Something the think about.
The house walls and soffits are finished with vinyl siding, which appears to be over the original finish of ___________. This type of siding limited the inspector’s access to all wall materials behind the vinyl siding and soffit areas.
These inaccessible areas may harbor excessive moisture condition, water damage or pest infestation or infection. Some damage, cracks, excessive moisture condition were noted to section of the siding and trim work extending into the interior walls.
Areas of the vinyl siding noted damage, voids open section.
Further inspection required.
Ron Bibler
EXCELLENCE HOME/BUILDING INSPECTION SERVICE
Sonoma California Home Inspection - Exterminating & Thermal Imaging
Petaluma California Home Inspection - Exterminating & Thermal Imaging
Vacaville California Home Inspection - Exterminating & Thermal Imaging
04-30-2010, 12:44 PM #6
Re: Vinyl Fascia
Ron, I something very close to that, except where you say;
"Further inspection required.",
I say " additional inpection services are needed...".
04-30-2010, 12:54 PM #7
04-30-2010, 12:57 PM #8
Re: Vinyl Fascia
You don't nail it but I have used it on new construction using proper J-channels, etc. I don't like vinyl for siding but as soffit and fascia it can make a good looking and durable product. I especially like it with perforated soffit.
04-30-2010, 05:10 PM #9
Re: Vinyl Fascia
[QUOTE=Ron Bibler;129598] This type of siding limited the inspector’s access to all wall materials behind the vinyl siding and soffit areas.
These inaccessible areas may harbor excessive moisture condition, water damage or pest infestation or infection. [QUOTE]
What type of infection could be behind the siding?
04-30-2010, 05:23 PM #10
Re: Vinyl Fascia
[QUOTE=neal lewis;129636][QUOTE=Ron Bibler;129598] This type of siding limited the inspector’s access to all wall materials behind the vinyl siding and soffit areas.
These inaccessible areas may harbor excessive moisture condition, water damage or pest infestation or infection.WOOD DESTROYING FUNGI... AKA "Dry-rot"
