Results 1 to 2 of 2
Thread: 1975 Bryant panel ground bar
07-01-2010, 10:33 AM #1
This Bryant panel has common and ground bars that are connected as a unit. Common and ground wires are mixed together. Is this okay? I am not an electrician. I just want to be safe.
07-01-2010, 01:12 PM #2
Re: 1975 Bryant panel ground bar
Is this service equipment or another panel? Are you asking about both a ground and a neutral in the same buss hole?
Regardless of panel type the neutrals need to be one per hole. Grounds can typically be doubled up in certain size ranges.
