Results 1 to 2 of 2
Thread: Attic Mould
    jerri ellis's Avatar
    jerri ellis Guest
    Unhappy Attic Mould
    Help! I have an extensive amount of attic mould and I do not know where to start. I was quoted up to $6000.00 for cleaning and remediation. Is this right? My new roof only cost $4000.00. We have lived in a nightmare neighborhood for too long and want out and now this. It was built in 1978. Is the house even worth it? What and with whom do I start this process and not get screwed around? Thanks!
    Default Re: Attic Mould
    Starting with someone making a gable end truss (with the additional studs) out of a common truss, likely without engineer, and without any truss plates, I'd say that the mould was the least of your problems.
    I am not a big fan of those who panic when they see some mould, crimeny, clean it up and get on with life. Who told you about the mould, a mold-is-gold inspector who makes a killing off scaring people and then makes more remediating the mould?
    Looks like a ventilation problem which needs to be corrected, then allow the mould to die on its own.
    I'll let others chime in here, but unless you or a member of your family is having allergic reactions to something unknown (in which case get tested and then see if it really is that mould which is causing the problem) I don't see what the big deal is.
