Results 1 to 3 of 3
08-16-2010, 02:42 PM #1
200 amp service with a 225 service panel
Probably a simple answer to a simple question but how do you have 200 amp incoming service and have a 225 service panel with a 225 disconnect?
Thanks,
Jim
08-16-2010, 04:03 PM #2
Re: 200 amp service with a 225 service panel
The demand load calculation for the home determines the size service required. If you have a 200 amp service and the service entrance conductors were sized for 200 amps you could not connect them to service equipment with ocpd of 225 amp.
08-16-2010, 06:40 PM #3
Jim, are you talking "incoming service" from the utility company? If so, its their property and they can size it as they see fit. Also with overhead service if I remember correctly, since the wires are not in a conduit and exposed to weather, cold, rain etc. they can get by with a even smaller gauge wire due to less heat buildup. I am sure some experts will be along soon quoting all kinds of codes.
Paul Kondzich
Ft. Myers, FL.
