Results 1 to 12 of 12
    Default Direct vent and openable window
    New construction... Direct vent fireplace in a living room with an openable window directly above it. Is there any reason why this might be okay? I'm having a hard time believing that no one else caught this before an occupancy certificate was given.
    David Banks's Avatar
    David Banks Guest
    Default Re: Direct vent and openable window
    Quote Originally Posted by Reis Pearson View Post
    Most Direct Vents only require 1 foot clearance to open able windows.
    Mechanical vents 4 feet. Check Install manual on web if you took name and model number.
    Reis,
    What type of siding/panel system is that?
    Reis,
    Whatever it is, it ugly.
    Reis,
    Hardiplank... very popular around here.
    David Banks Guest
    Looks like an apartment house in the Soviet Union.
    Reis,
    That's not HardiePlank.
    It might be HardiePanel, except that does not look like HardiePanel (surface texture) nor does that vertical joint treatment look like anything shown in the HardiePanel installation instructions ... thus I suspect it is not HardiePanel either.
    Reis,
    Pardon... yes, it's Hardipanel, this was actually done as a rain screen system.
    South-West Michigan
    Post Re: Direct vent and openable window
    Check the manufacturer's instructions carefully. It is surprising what has become acceptable under the new building codes. One example is attached. In the instance of a direct-vented fireplace producing less than 50,000 btu, it can be as close as 9 inches to an operable window. Not the healthiest thing, in my own opinion, but it is allowed by code. The code refers the code official to the manufacturer installation guide.
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
    Fuquay Varina, NC
    It's not a good idea but really how many people open a window in the winter while the heat is running.
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
    Tim Ball's Avatar
    Tim Ball Guest
    Mike, I'm installing an oil fired water heater that's 148,000 btu. Does this appliance then need 4' to an opening window or door? Thanks, Tim
    Fuquay Varina, NC
    Tim,
    Read post #2. and "always" read the manufactures requirements for they provide the answer you seek.
