Results 1 to 21 of 21
Thread: What Are these?
02-26-2012, 01:31 PM #1
What Are these?
Inspected a 9 year old home yesterday and the main beam in the garage ceiling had boxed out drywall enclosures below it. They are about 2 x 2 x 5. There are columns on the floor above bearing on the beam right above these ceiling enclosures (supporting the roof). What the heck are these enclosures? Seem to be some type of re-enforcement for the beam where the columns above bear on it?
Any one have any ideas?
JP
02-26-2012, 03:13 PM #2
Re: What Are these?
Any chance there is duct work following the joist cavity then ducking under the beam?
02-26-2012, 03:16 PM #3
Re: What Are these?
Whats upstairs??
02-26-2012, 05:05 PM #4
Re: What Are these?
Although there may be something running through it, my feeling is that it is architectural. What was the rest of the design like?
02-26-2012, 09:33 PM #5
Re: What Are these?
Above the garage is the living room /dining room, separated by a load bearing wall that goes up to the roof, large beam under the wall has two steel columns that support the structure. These two columns bear on the beam visible in the garage ceiling and these boxed in enclosures are directly below where the columns of the floor above bear on the beam. Definitely not ductwork, which is in the perimeter of the building. Home is a modern contemporary and was designed by an architect/engineer.
All I can think of is that since this is the garage, they did not want to install columns that would be in the way of parking vehicles, and there is some type of buttress like structure or renforcement that was added to the beam to strengthen it where the columns bear down on it.
No sagging, cracking of the drywall nor any other adverse conditions were noted, so whatever they did is functioning as intended and is not a concern. I just have never seen anything like it in 20 years and was wondering if any engineers in our group might know what these are, what they are called and how they work.
Thanks JP
02-27-2012, 01:54 AM #6
Re: What Are these?
Maybe asking the seller a question or two would be in order, especially if he/she is the architect/engineer who designed it.
02-27-2012, 09:30 AM #7
Re: What Are these?
If these are designed to strengthen the beam it seems logical that their long dimensions would be parallel to the beam instead of perpendicular. Perhaps this buttress is fastened to the adjacent joists to try and distribute the load? Looks like a head knocker. Keep us posted if you get more information.
Curious,
Luc
02-27-2012, 10:55 AM #8
Re: What Are these?
Perhaps these are boxed out chases to run wiring, plumbing or hvac ducting under the beam, rather than drilling through the beam. I can't imagine any kind of structural beam reinforcement that would look like this.
Thom Huggett, PE, SE, CBO
02-27-2012, 11:37 AM #9
Re: What Are these?
The only times I've seen the like, they were to conceal heating duct work. Does the house have central heating and ductwork?
One reason for duct work to be run under a beam like that is that there is a steel I-beam under that drywall.
Another possibility is that this was a double wide mobile or modular home that was placed on a basement garage. Is that possible?
If the columns or posts above are needed to support the roof, is there a vaulted ceiling?
02-27-2012, 05:48 PM #10
Re: What Are these?
Doesn't really make sense as the beam would be designed to hold up the floor trusses, not the other way around.
I can see a steel column in the other room that supports the beam. Maybe it is a steel I-beam that they couldn't get in in one piece and has big bolt plates welded on to join the sections without support posts? Still doesn't really make sense considering the size of the boxes.
Would be a nice time to have a borescope!
02-27-2012, 08:33 PM #11
Re: What Are these?
Bet you lunch that they are enclosing duct runs that were routed under the beam, then up the wall that rests on the beam.
02-27-2012, 09:32 PM #12
Re: What Are these?
If the boxes are right under the columns holding the roof up, they must be structural. For attachment, or stability - something like that. What's the diameter of the columns?
JP said they were definitely not for ducts, it seems you should all give him the respect of believing him, since he was there and you weren't.
- James Burgh, 1754.
02-28-2012, 10:43 AM #13
Re: What Are these?
I would have to agree that if he said they are not HVAC Ducts then they are more then likely wiring chases or plumbing possibly both. Having been in the housing industry for twenty years I have done this myself when a beam was in the way. I have also seen it done on occasion during a Home Inspection. Typically Architects and Engineer do not take into consideration what needs to ran, during the construction process it is up to the Construction manager and the Sub Contractor to figure out and submit any structural changes that may need be made to the Engineer for approval.
Jeffrey Marsh
The right inspector, right away. ®
Central California Property Inspection
Bakersfield Ca
Bakersfield Home Inspector | Central California Property Inspections
02-28-2012, 10:55 AM #14
Re: What Are these?
Has the appearance of hollow core precast pretensioned construction.
02-28-2012, 02:40 PM #15
Re: What Are these?
Mystery Solved!
This was bugging me so I went back to the house today (vacant) to look around and listing agent had told me that the house plans were somewhere in the garage. The drawings only show a large steel I beam here with no other type of re-enforcement. I think it is just pure coincidence that the steel columns from the floor above happen to rest on the beam right at these boxed in enclosures.
Looking at the room above, there are floor air supply registers that line up exactly to these boxes- So that's what they must be (air ducts going under the beam) and explains their shape longitudinal to the beam. I was wrong to rule that out at first. John and Robert -you were right on! Good thing I didn't bet lunch or I'd be buying
Thanks a bunch
]JP
02-28-2012, 06:37 PM #16
02-29-2012, 10:29 AM #17
Re: What Are these?
You and me both, Vern (post #8).........
02-29-2012, 11:41 AM #18
02-29-2012, 06:15 PM #19
Re: What Are these?
My apologies to Thom and Vern- Jeese guys
JP
02-29-2012, 06:49 PM #20
02-29-2012, 08:22 PM #21
. (See post #2)
