Results 1 to 12 of 12
    Jul 2007
    Elmont, NY
    Cool New type Hangar for Dryer Duct ?
    Here is a new idea for supporting a dryer duct.
    A nearby electrical bx line wound into a loop.
    Default Re: New type Hangar for Dryer Duct ?
    I hope that is not a dryer duct........but you know that already I hope.
    www.BAKingHomeInspections.com
    Jun 2010
    Vancouver
    Sal sorry to say but that is not earth shattering nor is it worth posting. Yes it is not done right but we really want to see strange or things that you need help with. no offence but that was too easy and straight forward and not worth posting.
    Feb 2010
    St. John, KS
    Thumbs up Re: New type Hangar for Dryer Duct ?
    Quote Originally Posted by Sal Castro View Post
    I hope you wrote up the defect of this dryer duct!? I'm sure the report was IAW the current IMC Codes!? If not I have attached a copy:
    Good catch Sal!!
    And ...
    - the electric line laying on the copper pipe
    - is that plywood/osb between the 2x sill plate and block, any signs of rot or water intrusion?
    - what's the point of the insulation scraps, when the floor isn't insulated, did you feel any breezes, siding issues?
    Jul 2007
    Elmont, NY
    Yes, I wrote it up with an added note about unnecessary heat and stress on the wiring as well. Easy fix.
    Just thought I would post it to give some a little chuckle.
    Jul 2007
    Elmont, NY
    And ...
    no osb, no rot. They had put an extension and crawlspace behind that original 1950 foundation wall so i guess they felt the need for insulation.
    Quote Originally Posted by Bill Hetner View Post
    I hope this is a tongue n cheek comment.....
    Yep, not right. Very creative! But of course the dryer flex should not be there in the first place.
    877-466-8504
    Jul 2010
    Washington
    There should be rigid metal ducting in that space supported every 4'. Much less friction and more sturdy than the flex vinyl.
    mike huntzinger's Avatar
    mike huntzinger Guest
    Along with Luc commit it is also a fire issue with the vinyal flex duct
    Inspector 3500's Avatar
    Inspector 3500 Guest
    It's also an electrical code violation to support anything from the conduit unless its associated with wiring within.
