Results 1 to 2 of 2
    Default disp + DW on double pole breaker
    This is the first time I've seen this. The dishwasher and disposal are on a multi wire circuit like we usually see. However, in this case, instead of two individual single pole breakers, they are connected to a double pole breaker with a common trip (normally seen on 240v circuits). The breaker takes up two spaces on the bus so each item is fed by a different phase. They share a neutral in the NM 14/3 cable.
    In my own mind I believe this is acceptable but I just want to make sure.
    Is it ok?
    Default Re: disp + DW on double pole breaker
    Nevermind....I found my answer here > http://www.inspectionnews.net/home_i...-circuits.html
    Thanks for the previous posts.
