Results 1 to 11 of 11
Thread: Do I need a Structural Engineer?
10-30-2011, 10:16 AM #1
I am very interested in a house that has a problem. It's on a slab, the floor has cracked in two places and shifted at least 1/2". The crack is about 2' long in each place along outside walls. You can feel the height difference. The house is 50 years old, I can see that the gutters are clogged and the downspouts end 2' about the ground. I don't know how long it has been that way. Do I need a structural engineer or can a home inspector give me an idea whether or not this is a huge defect? Thanks
10-30-2011, 10:25 AM #2
Re: Do I need a Structural Engineer?
forgot photo!
10-30-2011, 10:35 AM #3
Katherine, I would check with a foundation specialist contractor. You already know the gutters and downspouts have likely contributed something to the undermining of the foundation and (or) slab. Be careful about removal of the old cracked tiles as they may contain asbestos. See this link: Asbestos in Your Home | Asbestos | US EPA
10-30-2011, 12:19 PM #4
Thanks for the advice and the link.
Katherine
10-30-2011, 01:37 PM #5
10-30-2011, 01:51 PM #6
Check to see if there are any home inspectors who are also engineers. You might be able to kill two birds with one stone.
10-30-2011, 02:23 PM #7
Naperville is 28 miles west of Chicago. Thanks, Google.
First, be absolutely sure the floor is a concrete slab. I once inspected a sunken 'slab' and found it to be a rotten wood floor. There was no need to call for an engineer that day.
Second, the crack in your pic looks to me that the concrete footings which support the walls are now 1/2" higher. The slab has sunk there. It is important for the footings to be solid because they support the structure. Often the slab is poured between the footings and only needs to support itself and the contents of the home. If the footings have settled badly, you might not want to buy.
Pick a knowledgeable Home Inspector, there are a couple that lurk here, and if he says the footings appear to be alright in the 50 year old home, then the slab might be repairable with leveling compound. I say 'might' and I'm looking at a little thumbnail pic.
10-31-2011, 04:48 AM #8
This is good advice, but I don't know of any floor tiles with a "fleur de lis" design that may contain asbestos.
Originally Posted by Hank Spinnler
10-31-2011, 06:22 AM #9
Is there a matching crack visible at the exterior of the foundation?
10-31-2011, 07:15 AM #10
1. There is nothing preventing (it is not banned) asbestos from being in "vinyl" flooring tiles, even those sold today. That "style" or design has been around for many decades, and was quite popular in the 60s, 70s and 80s, in both tile squares and sheet goods; BTW, despite what another responder has indicated, that design is NOT "fleur di lis".
2. I note depressions, significant where appliance or furniture leveling "feet" have sat (such as a range, refrigerator, washing machine, entertainment center, etc.) All we see in the photo is that the tile is cracked, damaged, dirty, and displaced.
3. The "slab" is not exposed, all we see is the dirty, old, neglected, cracked, deteriorating floor covering. There is no damage, crack, etc. of a "slab" actually pictured.
4. It would not be uncommon for such an area to show similar indications where it had later had carpet tack strips installed & later removed/torn out.
Such are rarely level or smooth, especially near walls, especially near outside walls, especially where wall plates/sole plates were attached to the "slab" by other than set/cast threaded rod with nut and washers.
Floor leveling compounds, such as gypcrete and others, are and were often employed. These deteriorate over time, especially high traffic areas, especially areas where the slab conducts moisture from the outside edge or from below. 50 years old doubtful the "slab" was upon anything other than stone or gravel upon earth, which in that general area (NW & W burbs) and vintage was generally clay capped and/or fill if on "slab" (late 50s through early 70s), quite a bit on drained boggy/swampy areas, and less than originally flat, assuming this "slab" is on grade, which we don't know, and the OP is ambiguous, heck could be basement "slab". By the OP's own description has been further aggrivated by failure to maintain roof and surface drainage systems.
Keep in mind that these floor leveling compounds also often times are found to contain asbestos fibers.
Premature leap based on the limits of what has been shared.
Without knowing the confirmed geo specifics of the conditions, should there be an actual "slab" crack or movement, and specifics of the development, still premature.
Of course a full & complete Professional Home Inspection is advised, its a part responsible due dillegance, as would some reasearch on your part, regarding the property development, and potential for redevelopment, expansion, etc. as is so popular in the midcentury sections of Naperville and adjacent burbs; and most especially of an older, poorly-maintained, neglected property.
10-31-2011, 07:54 AM #11
Katherine,
I work in the Chicago area. If you are interested in a home inspection or want to discuss any concerns about the house you can contact me anytime at:
800-573-1113
Home
