    Cory Bingley's Avatar
    Cory Bingley Guest
    Default Help with this pictures PLS
    Anyone want to take a shot at this pictures ? What are we looking at ?
    Thanks Cory
    Default Re: Help with this pictures PLS
    What are we guessing at? The split cast iron pipe?
    Sep 2009
    leonardo, new jersey
    Guess?? we are looking at sewer gas eating the top of cast pipe which is typical, that vents at a poor location of an adjoining intersecting roof line
    Joseph Ehrhardt
    Some crappy wiring.
    #1 Mix of Knob & Tube , Lamp Cord , NMSC, and Low Voltage .
    * unknown ( maybe coaxial cable) under split cast iron waste line.
    #2 Plumbing Vent before an Addition almost blocked it with abandoned low voltage wire ran thru it.
    David Bell's Avatar
    David Bell Guest
    The new intro pictures to This Old Shack?
    It is a cast iron sewer pipe with a crack in it. It should be replaced.
    I'll bet that knob and tube wiring is abandoned but you never know. (Sometimes a voltage sniffer will give a false positive reading if there is active wiring running parallel to the wire.)
    The plumbing vent is in a poor location and probably has been since they put the toilet in the house. If there's a flashing there at all, it is leaking.
    That wire is somebody's old radio antenna or Grandpa's safety line for sneaking out the window.
    The shingle siding is falling off. And there could be several layers on that old roof.
    Cory Bingley Guest
    Thanks People
    By any chance can anyone comment on the possible weld in the cast iron drain ?
    Quote Originally Posted by Cory Bingley View Post
    Thanks People
    Read this Cast Iron Welding ( 1st line in Red Sums it up)
