Results 1 to 4 of 4
Thread: Roof decking edges
08-19-2007, 10:29 AM #1
Roof decking edges
Similar Threads:Last edited by dan orourke; 01-01-2008 at 01:26 PM.
08-19-2007, 01:27 PM #2
Re: Roof decking edges
It may be an indication of roof deflection, Dan, but it is a sure indication that the builder didn't use plywood clips between the sheets.
08-20-2007, 12:00 PM #3
Seeing the edge seal revealed on panels may be an indication of deflection--probably is. It could also be nothing more than the difference in thickness from one panel to the next. Manufacturing tolerances are +,- 1/32" and thick and thin places on a panel can be more than that. You would be hard pressed not to find one or two of these "exposed" edges on most roofs.
I would not consider it a "defect" by itself. Also, while panel clips may be desireable on some roofs and spans, they may not code required. 7/16" Rated Sheathing as shown does not need edge clips for truss spaced up to 24" on center.
08-20-2007, 12:13 PM #4
Any difference in decking thickness would be visible on top of the decking, not from beneath where the decking is supported by the roof framing. The interior surface of the decking would not show any discontinuity (unless the framers installed shims between the roof framing and the decking).
Bruce Breedlove
www.avaloninspection.com
