Results 1 to 11 of 11
Thread: Proper Fitting
03-21-2012, 05:45 PM #1
Proper Fitting
This fitting did not look correct to me. It is directly under the toilet. The line from the left is the drain line from the bathtub. Normally, I see a San T, or something with more of a directional flow. This was more like a cross T. Is this fitting acceptable to tie in the tub drain line to?
Similar Threads:Jim Robinson
03-21-2012, 06:45 PM #2
Re: Proper Fitting
Looks to be an okay fitting.
Typically, you would see the side inlets as a sanitary tee because that is what the code requires for a change from horizontal to vertical, and those side inlets looked to be straight, not curved like a sanitary tee.
However, after some searching I found this: P418-338 - Spears P418-338 - 3" PVC DWV Sanitary Tee w/ 2" R and L Side Inlets
This shows a cut-a-way view and the side inlets are curved similar to a sanitary tee, even though the exterior of the side inlets look straight.
03-21-2012, 06:48 PM #3
Re: Proper Fitting
Just Curious Jim,
What's Connected to the Duct Taped Metal Vent Pipe ?
03-21-2012, 06:51 PM #4
Re: Proper Fitting
03-21-2012, 06:56 PM #5
03-21-2012, 07:00 PM #6
Re: Proper Fitting
The firefighters would fall because their boots got caught in the open risers with the full height opening ... just the right size for their boots.
Who needs a guard rail or handrail at that old basement stairs anyway? Silly things just get in the way and look ugly.
03-21-2012, 07:09 PM #7
Re: Proper Fitting
03-21-2012, 07:13 PM #8
Re: Proper Fitting
The metal pipe with the tape is the dryer vent.
Thanks for the help, all of you.
03-21-2012, 07:41 PM #9
Re: Proper Fitting
That's not the stair support, that's some type of wall. Look closely at the lower left corner of that photo and you will see the stairs are to the left in that photo. The photog was standing near the stairs and facing toward the bottom of the stairs for that photo.
03-21-2012, 07:42 PM #10
Re: Proper Fitting
Ten or twelve years ago I had to set for a test to get a permit to run my own sewer line when the septic died. One of the questions was to identify the picture of a "cottage fitting". Never heard of one before, but that is what they called the one pictured by Jim. No I didn't get it right! Been looking for one eversince.
03-21-2012, 08:51 PM #11
Re: Proper Fitting
That fitting used to be called a cottage fitting back in the day. Now its just known as a side inlet sanitary tee.
