    Western Montana
    Default Warm breakers, how much is too much?
    Pair of 60-amp double-pole breakers for an electric force air furnace. Both were warm to touch when the furnace was running. My infra red thermoter showed 92-114 degrees. Side note, the panel is in an old basement, so the ambient temp was in the 60's.
    I have only see a couple of electric furnaces before, so don't know if this is unusual. Didn't see anything else alarming in the wire run or at the furnace.
    How warm would be considered to be too warm?
    so so, California
    Default Re: Warm breakers, how much is too much?
    Quote Originally Posted by Terry Beck View Post
    HVAC always hotter than ambient when they are running. Just curious, What was the ambient temp when you took the disco temp?
    Western Montana
    Hey man, back in dem days of disco, I was HOT!!!. Me and Travolta. Boy oh boy.
    Sorry. long day.
    Ok - so what is a disco temp? I probably didn't take it.
    so so, California
    Sorry. long day.
    What was the ambient temperature when you measured the HVAC breaker.
    Western Montana
    As I said originally
    So we're talking about a rise of 40-50 degrees on the surface of the breaker as compared to surrounding air.
    Western Montana
    As it is, I am already calling out a long laundry list of other items that need the attention of an electrician. The property is originally 1916 with old barns, shops, tack rooms, pump houses. Lot's of places for Grampa Ned to screw up the wiring.
    so so, California
    It was pulling a load, of course it will be hot.
    Nov 2009
    St Paul, MN
    No more than 35 degrees above ambient.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    Ambient temperature rating will depend on breaker manufacture, but the temp should be on the breaker itself.
    Without knowing make of breaker, its a guess at the very least.
    Temperature Derating for Circuit Breakers
    Frequently Asked Questions
