Results 1 to 4 of 4
	09-28-2007, 12:31 PM #1 Electric furnace disconnect switch Electric furnace disconnect switchLast edited by Jeff Eastman; 12-11-2007 at 07:06 PM.
	09-28-2007, 05:27 PM #2 Re: Electric furnace disconnect switch Re: Electric furnace disconnect switchYes. The disconnect should be in the closet with the furnace.
 I know, someone is going to say 'but you are not going to be 'in' the closet and close the door, so you can still see if someone comes by and flips the breaker back on', yes, that is true, but ...
 The disconnect still "should be" in the closet, and that was the question.
 What is that stubbed out of the wall below the panel? A water cooler?
 This is that commercial building right (I can see the drop ceiling lay in tiles)? Definitely in that case.
	09-28-2007, 08:13 PM #3 Re: Electric furnace disconnect switch
		If a disconnect is required in that closet, couldn't you just place a lock out on the breaker in the panel as an alternative?The disconnect still "should be" in the closet, and that was the question. Re: Electric furnace disconnect switch
	09-28-2007, 08:54 PM #4 Re: Electric furnace disconnect switch Re: Electric furnace disconnect switch
