Thread: Interesting pipe fitting
05-04-2013, 07:03 AM #1
I had not seen one of these fittings before.
05-04-2013, 09:07 AM #2
Re: Interesting pipe fitting
05-04-2013, 09:26 AM #3
Pretty cool. Looks like age may have caught up to it.
05-04-2013, 10:28 AM #4
Yep, pretty cool! You are right about getting to the end of it's life. There were lots of heavy rust blisters, copper/galvanized connections, and a few leaks too.
05-04-2013, 02:52 PM #5
Time to replace that mess.
05-04-2013, 02:57 PM #6
Crossover fitting? That is all I ever heard those called. Few and far between, only see these a handful of times each year...
05-05-2013, 03:02 AM #7
05-11-2013, 06:20 AM #8
05-20-2013, 03:25 PM #9
05-25-2013, 10:26 AM #10
Since you answered with a question mark, I'll confirm.
simply "crossover" or as "crossover fitting", is correct; as is, and more commonly WAS "cross-over" fitting, coupling, bend, etc. or "cross over" fitting, etc. Not to be confused with a cross (four-way) or a cross or cross-over connection.
Here is how the web-based version of the McGraw-Hill Dictionary of Architecture & Construction hosted by "answers.com" defines it for you:
crossover
2. A pipe fitting shapped like the letter "U" with the ends turned outward; used where one pipe crosses another in the same plane; also called a crossover fitting.
clickable link for reference: Architecture and Construction: cross grain to crotchet from Answers.com
An expansion U bend or double offset expansion U bend or double-offset U-bend can accomplish similar in slightly differing manner.
