    dan orourke's Avatar
    dan orourke Guest
    Default Hardboard or hardi Plank siding
    Default Re: Hardboard or hardi Plank siding
    If the nails were not blind nailed (you cannot see the nail heads), but was face nailed (you can see the nail heads), the nail heads should be flush to (not flush with) the surface on hardboard as when the nail is driven 'flush with' the surface, the nail head breaks the surface and exposes the inner crap to the weather.
    Same with Hardieplank, I think.
    At least, that's the way I remember it.
    Quote Originally Posted by dan orourke View Post
    yeah, they faced nailed....but do they need to be sealed?
    If the nails are 'flush to', not to my knowledge.
    If the nails are 'flush with', then it really does not matter anyway ...
    You didn't answer which they were ... 'flush to' or 'flush with'.
    Richard Rushing's Avatar
    Richard Rushing Guest
    I'm pretty sure that it's:
    Hardbaord siding-- yes (sealed)
    Hardieplank-- optional
    rr
    gainesville fl
    from jameshardie.com check top of page 3
    www.jameshardie.com/pdf/install/install_plank_south.pdf
