Thread: concrete fan housing support
12-07-2007, 10:11 AM #1
Should I have called for a HVAC contractor or a mason?
Similar Threads:"There is no exception to the rule that every rule has an exception." -James Thurber, writer and cartoonist (1894-1961)
12-07-2007, 06:23 PM #2
Re: concrete fan housing support
I'd call aplumber. Didn't you see the toilet seat jammed under the other side!
12-07-2007, 08:38 PM #3
I was thinking 'concrete finisher' as that is kinda rough ...
12-07-2007, 08:42 PM #4
From the looks of the unit and that rock... you need an archaeologist.
rr
12-09-2007, 05:48 AM #5
Looks like the floor threw up.
12-09-2007, 06:36 AM #6
The Air Handler most likely was experiencing High Vibration due to the Corroded base of the unit.
Packing cement under the Blower curbs the vibration.
Typical professional HVAC repair in Philadelphia.
What, Youse guys never seen dis before?
