Thread: What is HDPF?
04-27-2017, 09:40 PM #1
04-28-2017, 03:47 AM #2
Re: What is HDPF?
With Google I only found HDPE (high density poly ethylene). Its possibly thats what this is and part of the E was worn off.
04-28-2017, 04:34 AM #3
Re: What is HDPF?
Thanks Jack. I only found HDPE in an on-line search too. It must have been a bad day with the printer because it made several E's look like F's.
04-29-2017, 11:01 AM #4
Re: What is HDPF?
I looks like a misprint. I found this on the Centennial Plastics site:
Potable Water : Centennial Plastics, Inc.
04-29-2017, 05:58 PM #5
Re: What is HDPF?
I looked in the IRC and neither Table P2906.4 Water Service Pipe (only allowed for use of the water service pipe outside the foundation) or Table P290-6.5 Water Distribution Pipe (permitted for use inside and throughout the house) lists HDPE as being approved for either use.
I also looked at the ASTM number (as best I could read them) and did not see the ASTM number listed in either table - thus it appears that HDPE piping is not approved for use as water service pipe (which is what you described the use as), much less water distribution pipe (if any was used inside).
05-01-2017, 06:08 AM #6
Re: What is HDPF?
I had to look it up, and found this at Charter Plastics.
D2239 is rated for down the well applications and underground installations.
However, it is not designed for in house use or for hot water applications.
Connections should be barbed fittings and clamps.
Instructions say that "New water mains and service lines should be disinfected according to AWWA C651."
05-04-2017, 08:18 AM #7
Re: What is HDPF?
Apollo Home Inspection
St. George UT
