12-24-2007, 01:10 PM #1
Carport Codes for New Construction
12-24-2007, 02:16 PM #2
Re: Carport Codes for New Construction
12-24-2007, 05:24 PM #3
Yep, that's a carport.
All depends on the uplift and the steel properties - i.e., depends on the engineering.Also, isn't there suppose to be 4 bolts securing the post to the slab, not 2?
Depends on the rating of the walls and any openings in those walls: 0 feet, 3 feet, 5 feet, 10 feet, 20 feet, or 30 feet.Does anyone know the minimum distance between building structures?
12-25-2007, 09:59 AM #4
Agree with the above and highly recommend "Significant Changes to the IRC 2006" by Hamid Naderi PE & Douglas Thornburg AIA, IMHO a must have for all inspectors. The attachment below is from Section 302 which has been totally changed from the 2003 version.
12-25-2007, 10:22 AM #5
Here's an explanation and appropriate table.
