03-24-2019, 12:34 PM #1
Coffee Makers...considered Hot Plates...???
hello again...
Commercial Insurance (Loss Control) Inspector here...fist time in 6 years I have encountered this...a coffee make in a sleeping room (rooming house). Is it considered a hot plate? And is so, what code could I cite?
thanx,
dox
03-24-2019, 01:14 PM #2
Re: Coffee Makers...considered Hot Plates...???
A couple of questions:
- Do you have a photo of the coffee maker?
- Why would you consider a coffer maker a hot plate? (Maybe the photo would answer that?)
03-24-2019, 01:27 PM #3
it has a flat cooking surface containing a heating element
03-24-2019, 02:29 PM #4
A lot of things have heating elements. (curling irons, hair dryers, soldering irons, Easy bake ovens, reptile terrariums, etc.)
If it's UL listed and labeled as a "coffee maker", it's not a "cooking surface", and it's not a "hot plate".
Dom.
03-24-2019, 03:05 PM #5
If you are describing what I am envisioning, it has one, two, maybe even three four "warming" plates that glass coffee decanter are placed on to keep the coffee warm.
As Dom said, those are not "not plates".
Is someone using that as a hot plate? Maybe, but that doesn't make it a hot plate anymore than sleeping in a recliner chair makes the recliner chair a bed.
03-25-2019, 09:18 AM #6
look fellas...
the definition of hot plate is 'flat cooking surface containing a heating element'.
The context here is that of a general liability insurance inspection, in a rooming house. sleeping rooms are not permitted to have hot plates, of any sort; and if the above definition doesn't describe a coffee maker, I don't know what does. generally speaking, If the occupant leaves the room w/ the coffee maker still on, it seemed to me that would constitute a fairly large liability issue.
I thought maybe someone here had some experience w/ this subject...or could provide some code reference, that's all...'cause on it's face value, a determination of that sort 'does' seem like an overzealous one. wasn't attempting to ruffle ay feathers...sorry
dox
03-25-2019, 10:08 AM #7
03-25-2019, 11:42 AM #8
If the occupant leaves the room and ANY appliance is left on (iron, coffeemaker, TV, computer) ... yes ... there is a risk.
And if the insurance policy and rules state "no cooking" ... that's one thing (and yet another to enforce and catch, but if they state "no hot plates of any sort", then look up how "they" define "not plate" (was that the definition you gave?), and if it says "cooking" surface, a coffee maker keep warm surface is "not for cooking".
If the definition says no "surface" with a heating element, then no coffee maker with a heated plate, no iron, not computer with a heat sink cooling surface, no etc.
03-25-2019, 02:16 PM #9
03-26-2019, 05:37 AM #10
The functional difference:
A teakettle or coffee maker heats a liquid (essentially water) and will not get hotter than 212 degrees f, so long as water is present. If it's working as designed, it would be really hard to start a fire with one of those.
A hot plate working as designed gets hot enough to start a fire if paper or cloth comes in contact.
It's reasonable to exclude one but permit the other.
A failed coffee maker could indeed start a fire. So could a failed radio, or computer, or other electric powered device.
