Results 1 to 2 of 2
10-29-2019, 07:55 PM #1
Bent Nail Inspections Salt Lake City - Unexplained Increase in water consumption
To give you some ideas of what might be causing the unexplained increase in water consumption, here are some facts.
According to the EPA, the average family of four uses 400 gallons of water a day. If a home has one or more leaky faucets, a drip rate of one drip per second will waste more than 3,000 gallons of water each year. Leaks can be found by reading the water meter before and after a two hour period when no water is being used. If the meter does not read exactly the same both times, there is likely a leak somewhere. This problem can usually be fixed by simply replacing any worn faucet washers. On the bottom of the faucet stem, a screw holds a rubber washer in place. Unscrewing the washer and replacing it with a new washer of the same size may eliminate the leak. Washerless faucets have O-rings instead of washers that provide a seal.
A leaky toilet also presents a problem by wasting about 200 gallons of water every day. A toilet leak can be diagnosed by placing a drop of food coloring in the tank. If the color shows in the bowl without flushing there is a leak.
If the toilet was purchased before 1992, it is probably an inefficient model that uses between 3.5 to 7 gallons of water per flush. New and improved high-efficiency models use less than 1.3 gallons per flush. Upgrading to a new toilet can save a family of four roughly $1,000 over 10 years.
Similar Threads:Davin Strand is the owner of Bent Nail Home Inspections, LLC
10-29-2019, 08:02 PM #2
Welcome to InspectionNews!
Thank you for registering and posting your message here.
If there is anything I can help you with please let me know.
InspectionNews has many Member Benefits available to you. Some save you time, others save you money and some do both!
Make sure you view the list of Member Benefits at: http://www.InspectionNews.net/home_i...MemberBenefits
Sincerely,
Brian Hannigan
Twitter: @InspectionNews
