Results 1 to 3 of 3
    Default Trip Tie Required?
    Greetings HI's,
    I'm sure this is covered in Elec101, so thank you for being patient.
    I performed an 11 month inspection on a home today and saw what I believed to be 4-wire romex with one wire connected to a 20amp breaker for the disposal and the other connected to a separate 20amp breaker for the dishwasher. They share a single neutral and ground.
    Question: Should there be a trip tie between the breakers?
    Additional comments are welcome.
    Thanks,
    Michael - Scher Professional Inspections- Austin Real Estate Inspector
    Tampa, Fl
    Default Re: Trip Tie Required?
    If they are in the same outlet/junction box they need a common trip.
    If on the same yoke/strap (i.e., a duplex with disposer and dishwasher - both on same device) - tie handle required.
    Could be in same box and tie handle not 'required' - but a really, really, good idea.
