Results 1 to 3 of 3
    Fuquay Varina, NC
    Default Lights and receptacles on same circuit
    Second floor was just finished off this year on a 1996 built home. It was an unfinished second floor when built. The receptacles and the lights are on the same circuit. I thought lighting and wall receptacles where on the there own dedicated circuits. Is it required?
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
    Default Re: Lights and receptacles on same circuit
    Nothing wrong with having them on the same circuit code-wise.
    Of course, if the breaker trips, everything goes off.
    One argument I make about that is for the simple part of being able to supply at least lights with a small generator if the power goes out. Or if you have receptacles go out for some hidden reason you still have lights.
