09-28-2020, 08:53 AM #1
A dangerous patent for "self-grounding" receptacle outlet
A dangerous patent for "self-grounding" receptacle outlet:
https://www.mikeholt.com/newsletters...&letterID=2223
Similar Threads:- Outlet "Tester" sampler panel
- Airflow "through" a building or "beneath" the exterior cladding
- High potential cost to correct "minor" defects at "commercial" sliding doors
- High potential cost to correct "minor" defects at "semi-commercial" "standard" doors
- 410.8 governs "clothes closets", but what about "storage cabinets"?
10-21-2020, 05:46 PM #2
Re: A dangerous patent for "self-grounding" receptacle outlet
Agree is dangerous defeats the entire point of keeping separate grounding and neutral. hopefully never allowed to be put into practice. Maybe anyone can go to US patent site and file a complaint, they may not since do not see as a regulating body but maybe can revoke the patent ? Should not be allowed to be manufactured.
10-21-2020, 06:05 PM #3
I see questionable stuff for sale at the big orange box and the big blue box fairly regularly. How long before these devices are available in the bins immediately next to an approved device? I don't believe that most of the folks who purchase stuff at the home centers are likely to look closely enough at products to find out if they are listed.
The alternative is that they will begin selling them through online retailers. "Hey, it's patented. It must be okay."
10-22-2020, 11:50 AM #4
There is almost nothing you can do to stop stupidity and underhanded contractors.
I rewired an entire house that the owners had paid someone else to re-wire. Turns out the owners were after grounded receptacles and the contractor simply jumperd the grounded conductor to the ground screw.
I took pictures of every violation I found on the job and the owners still had to take the other contractor to court. I guess the other contractor could claim prior art and sue if it ever got into production. Then the owners could get their lawsuit settled.
Unfortunately, discussing US Patent Office issues gets us into politics.
10-22-2020, 04:56 PM #5
12-13-2020, 06:31 AM #6
Self Grounding Receptacles have been around and available for decades ! They are nothing new.
12-13-2020, 08:11 AM #7
Not "self-grounding" in the way those are "self--grounding".
Those are designed to "self-ground" the neutral to the ground so as to be installed in an ungrounded circuit and provide a "ground" to a grounded plug ... by way of being bootlegged back to the bonded neutral terminal to ground.
12-13-2020, 09:09 PM #8
I think "self-electrocuting" rather than "self-grounding" would be a better description.
But, that might not look so good on the packaging.
