Results 1 to 3 of 3
Thread: Flue and Plumbing Vent
02-25-2009, 02:42 PM #1
The flue vent and plumbing vent are directly next to each other. I would think that there should be some separation between the two, but how much is enough? I doubt anyone will do anything about it now anyhow. The plumbing vent is copper, if that makes any difference.
I got the 2 feet above the wall next to the flue vent pipe already noted in the report.
Similar Threads:Jim Robinson
02-25-2009, 02:51 PM #2
Re: Flue and Plumbing Vent
You also noted that was not a Type B gas vent cap, I presume.
To my recollection (without looking it up) there is no separating requirement between the two.
I am sure I will be bashed for not looking it up and will subsequently be beaten into submission for being incorrect.
02-25-2009, 04:13 PM #3
If that is type B-vent, then what happened that they replaced the listed termination with an unlisted one? Rot away from improper operation, blown away, damaged by roofers?? I would want to pull that cap and inspect the venting.
I'm not aware of a clearance to the stink pipe (technical term) per se
