Thread: Bolts through glue lam
06-17-2009, 08:43 PM #1
Any thoughts on these photos. Typically I see ties used at these connections.
06-17-2009, 11:09 PM #2
Re: Bolts through glue lam
It's hard to say from the picture what's going on. With that 'end grain' connection I'd say the screws should hold the smaller glue-lam in place for decoration... maybe. Hopefully, there's not a load on it. And, hopefully some engineer or architect approved the holes through the larger glue-lam that appears to be structurally significant (I'm thinking not).
From what the pictures show you have more than enough problems or questions to recommend plans/permits from an engineer be obtained. There is quite possibly no such documentation. That appears to fall well outside of anything you'll find in a code book and would need to have been engineered.
On edit - I suppose that smaller glue-lam could be a collar tie of sorts as I really can't see a load on top of it. It's still a poor connection with holes bored through the large glue-lam. It's beyond what a HI is there to do and you're well within reason to call it out for further review.
06-18-2009, 02:33 AM #3
For your report defer to the design professional. for your personal interest:
http://www.apawood.org/pdfs/managed/...TOKEN=58895006
06-18-2009, 06:25 AM #4
Thanks for posting the pdf's Aaron. I don't usually see glulams but nice details to have for when I do.
Markus
06-18-2009, 09:03 AM #5
Lotsa' good stuff in there - Thanks!
