	02-09-2010, 06:51 AM #1 Gas Hot Water heater exhaust pipe Gas Hot Water heater exhaust pipeThis is a picture of a hot water heater that is located in a corner under a deck of a 1850 built house. Can the exhaust pipe be vented that short of distance under a wood deck? This is not in a enclosed area.
 Thanks,
 Jim
	02-09-2010, 06:58 AM #2 Re: Gas Hot Water heater exhaust pipe Re: Gas Hot Water heater exhaust pipeIt is, therefore it "can be", but it should not be.
 It should terminate above the roof.
	02-09-2010, 07:04 AM #3 Re: Gas Hot Water heater exhaust pipe Re: Gas Hot Water heater exhaust pipeAlso the Flexable (gas) connector should not be longer that 3', that one looks to be much longer than that.
	02-09-2010, 07:22 AM #4 Re: Gas Hot Water heater exhaust pipe Re: Gas Hot Water heater exhaust pipeLooks like PB tubing also.
	02-09-2010, 11:25 AM #5 Re: Gas Hot Water heater exhaust pipe Re: Gas Hot Water heater exhaust pipethe installation is wrong for too many reasons to mention and why heat hot water?
	02-09-2010, 06:47 PM #6
	02-09-2010, 06:59 PM #7 Re: Gas Hot Water heater exhaust pipe Re: Gas Hot Water heater exhaust pipelooks like the tubing on the pressure relief is pitched backwards also.
	02-09-2010, 07:43 PM #8 Re: Gas Hot Water heater exhaust pipe Re: Gas Hot Water heater exhaust pipeJim,
 Start with the minimum height of the vent and go from there (I've only listed a couple of things).
 Minimum height of the vent is 5 feet from the draft hood to the lowest point in the gas vent cap.
 Minimum height is also 2 feet higher than any obstruction within 8 feet horizontally.
 From just those two things, you can see where this is going ... downhill fast.
 Also, define 'not in an enclosed area' as that water heater is not approved for use outside ... as I said, it is going downhill fast ...
 Add to that the PB being outside, exposed to sunlight, not protected from freezing ... I could go on and on and on ...
  Reply With Quote Originally Posted by brian schmitt
