    Greg Frazier's Avatar
    Greg Frazier Guest
    Default Multiple grounds under one terminal
    Was this ever allowed? (Maybe a poor choice of words. It was obviously "allowed" 19 years ago by the AHJ.
    georgia
    Default Re: Multiple grounds under one terminal
    no, if you look at the label on the panel it will tell the number and size of the conductors allowed in that lug and the other ground bars in the panel. Make sure you look at it correctly most allow only one grounded conductor but do allow multiple grounding conductors.
    Greg Frazier Guest
    Forgot I took a pic of the label.
    georgia
    That label shows that 1 #6 up to 1 2/0 are allowed no multiple conductors and no conductors smaller thal #6.
    Nolan Kienitz's Avatar
    Nolan Kienitz Guest
    Common practice years ago to twist all branch circuit grounds and go for one termination.
    The SEP installed when my house was built in 1982 was done that way. I had the SEP replaced last fall and the electrician corrected all the 'old ways' and did it right (at least to current standards).
    Making sure that no one thinks that was right back then, so I am pointing this part out:
    ... and the electrician corrected all the 'old ways' and did it right ...
    I.e., the old way was "common", but it was also "never the right way".
