Results 1 to 3 of 3
Thread: Sill Plate
    Heron Longoria Jr.'s Avatar
    Heron Longoria Jr. Guest
    Default Sill Plate
    Anybody out there know if you can use plywood strips as your bottom plate in wall construction?
    I say no, the IRC says it must be a nominal 2 by member equal to the same size of studs it supports... to me the intent is a 2 x 4 stud should be used as sill for a 2 x 4 wall.
    Heron Longoria Jr. Building Inspector III
    City of McAllen
    chris mcintyre's Avatar
    chris mcintyre Guest
    Default Re: Sill Plate
    Quote Originally Posted by Heron Longoria Jr. View Post
    Yes, well OSB, if it designed for that use. We used a segmented OSB plate for curved walls, it was 1 1/2" thick, I think it was an I-Level product.
    City of McAllen
    Heron,
    Welcome aboard.
    The answer to your question - using plywood - is no.
    Plywood is not designed or intended for compressive loading like that.
