Thread: Electrical panel
06-23-2010, 01:54 AM #1
Electrical panel
Good morning. What is happening when some of the breakers in a panel are warm or even hot to the touch?
06-23-2010, 05:18 AM #2
Re: Electrical panel
Heat is generated by the current flowing through the breaker. This heat is what causes a breaker to trip on overload.
Abnormal levels of heat could point to a problem.
06-23-2010, 07:13 AM #3
Were they AFCI breakers?
06-23-2010, 07:14 AM #4
Well, at least in many modern designs, not exactly, see for example:
HowStuffWorks "Basic Circuit Breaker Design"
06-23-2010, 08:32 PM #5
Most all breakers of modern manufacture (that you're likely to find in a residence) have both a magnetic and thermal component to the trip mechanism.
An illustration that does not reflect actual trip curves but illustrates the point is a 15 AMP breaker may carry 16 Amps for many hours before tripping, but will trip much sooner with a 30 AMP load.
The magnetic component makes for instant tripping when a fault occurs.
Older breakers may lack the magnetic component
06-23-2010, 08:49 PM #6
06-30-2010, 05:22 AM #7
I had an electric water heater turn on while I was inspecting a panel and the 30 Amp breaker heated up to about 100 degrees.
