Results 1 to 4 of 4
07-24-2010, 09:22 AM #1
vinyl on less than vertical surface?
Subject house has a two-story sun room and top room is of a smaller footprint that lower. So there is an angled section, like a short shed roof, at approximately 30 degrees. I have the VSI manual and can't find any mention allowing/disallowing this. I don't think you should do this for several reasons but can't find documentation to support it. Standing seam metal roofing or other would be great here.
07-24-2010, 11:21 AM #2
Re: vinyl on less than vertical surface?
I would call it a roof, so I say, no vinyl siding should not be used there. I see a lot of other things going on that are not right, looks like a DIY gem.
Is the upstairs door operable?
07-24-2010, 11:23 AM #3
07-24-2010, 11:31 AM #4
IMO it's wise to explain to clients that ALL vinyl siding is a decorative - not a water proof - material - and that in EVERY case it is must be installed with the understanding that substantial amounts of water will get behind it.
