Results 1 to 4 of 4
    WESTMINSTER CO
    Default OLD JANITROL FURNACE VENT PIPE
    hey guys
    this janitrol had a belt drive--and manuel said 7/1963--but could not find serial #--the sellers hvac guy okd it--is the venting on this right--looks like crap to me--heck i graduated high school in 1965--and i don't work correctly
    cvf
    WESTMINSTER CO
    Default Re: OLD JANITROL FURNACE VENT PIPE
    sorry furnace guts
    No. There is little-to-nothing right with the entirety of the vent connectors or the overall venting system pictured.
    Neither is the WH (connector from same - tape, caddy-whumpus draft hood, offsets b/4 rise, undersized - tape again to s/w fitting - pex w/in above space of footprint on cat I and w/in inches of s/w connector; nor the manifolding connection to the B-Vent fitting & same's orientation, nor clearances, support, nor blocking/stopping. It is unquestionably not 1960s or 70s venting or vent connectors.
    The fuel gas code addresses. IIRC you are also at higher altitudes in your "neck of the woods".
    It also appears somewhat obvious the area has been additionally enclosed since original installation and construction.
    What is less-than-obvious is the conditioned/non-conditioned status of the area, the overall height (rise) of the venting system, the functioning rating (adjusted) of the entirety of the equipment, what other equipment may be present (such as mechanical ventillation, clothes dryer, etc.) nor the available cubic footage and natural air exhange rate of the area.
    Randy Rogers's Avatar
    Randy Rogers Guest
    I think I would move the union on the gas line out of the unit, as well.
