    Christian Tag's Avatar
    Christian Tag Guest
    Default Lintel required ?
    Hi all,
    I was wondering if this kind of stone needs lintel to support. It looks like its glued on the plywood underneath. The job was done a year ago by the homeowner, no sign of crack on the mortar so far.
    Christian Tag Guest
    Default Re: Lintel required ?
    I forgot to ask, do I need weep holes ? Since its stock on plywood, what would be the purpose of having weep holes ?
    Quote Originally Posted by Christian Tag View Post
    Hi all,
    No lintel or weep holes required. Think of the faux stone as fancy stucco, it has almost the same install and application requirements.
    FYI, it is not installed properly. You should not be able to see the wood framing. It should have a finished bottom and flashing.
    Christian Tag Guest
    Thank you Scott for your fast reply,
    What kind of finished bottom you mean?
    I think Faux Stone will be (is) the New Stucco.
    Here is a basic installation manual that will help you to learn about this building product.
    Jul 2007
    Chicago
    That is a good PDF for guys to add into their files Scott.
    I have the same one.
