    Floyd Thorne's Avatar
    Floyd Thorne Guest
    Default HEHISLLC
    Default Re: Hello I'm new to the feild of HM
    Quote Originally Posted by Floyd Thorne View Post
    I have been working as a natural gas service tech, for 30 years and decided to make a change.
    Welcome, Floyd!
    I think. "HM"? You sure you have the right forum?
    Floyd Thorne Guest
    Red face Metal Roofs
    Welcome, Floyd!
    Got a question for ya John. How far should a metal roof tuck under another roof that slopes down to it so the water does not track back up into the attic as a leak? P.S. There is no flashing because of the corragated metal ...
    Default Re: Metal Roofs
    Even with metal roofs you will or should and can have flashing......
    I'm trying to visualize what you are describing, do you have a picture?
    Elliot Franson's Avatar
    Elliot Franson Guest
    Mr. Thorne: Yes, what exactly do you mean? Almost any transition from one type of roofing material to another will require flashing. And there are corrugated metal flashings made just for such transitions.
    Floyd Thorne Guest
    No I do not have a picture but mabe can explain better. The main roof slopes down to a differant pitch roof. Where they intersec is the problem.
    Floyd Thorne Guest
    Default HEHISLLC
    Welcome, Floyd!
    Type "O"s happen! HI was the thread..... Thanks John.
