Results 1 to 30 of 30
    Default jackleg deck structure
    This deck had no beams. It was all just joists lag, (not through) bolted to 4x4's. No beams, no bearing.
    Nice huh?
    Default Re: jackleg deck structure
    Nice huh?
    John,
    Your photo is showing beams ...
    John,
    I thought a beam had to be two 2x pieces of dimensional lumber fixed togeather.
    How exactly do you define "beam" as applied to the picture?
    How about " that beam in the middle of the photo" ?
    Sep 2007
    Fredericksburg, VA
    I had a deck yesterday so bad that I started the comment with, "This deck is a catastrophe waiting to happen" The only parts that had bolts were the railing posts to the skirt board. A set of wide and long steps could, really, fall down at any time. I've seen some bad decks but this one goes to the top of the heap; for the time being anyway.
    Stu, Fredericksburg VA
    Beam: A horizontal structural member, such as a girder, rafter, or purlin, that transversely supports a load and transfers the load to vertical members, such as columns and walls.
    Succasunna NJ
    John,
    Your thinking of a 'Built-up' beam.
    The beam in your photo is (probably) undersized.
    A beam can be any size or number of pieces from one to as many as needed for heavier loads.
    The beam spans from bearing point to bearing point and carries loads attached to it, such as those joists which are carried on that single member beam which is supported at each end.
    I'm enlightened. I did not know that a single 2x8 could be considered as a beam.
    Thanks for clarifying the definition.
    Beam purpose is to distribute load between points.
    Side note...
    A Beam can be made of any material or combination of materials.
    Talking Re: jackleg deck structure
    I've seen a few that were made from termites holding hands.
    What material is a beam of light made of?
    Jan 2011
    Utah
    A "Beam of Light" is made of Photons.
    Excited particles. Unless it part of a ham and beam casserole.
    Mar 2011
    Sparks,NV
    It's a beam but I do know allot of builders that only call a beam something that is a 4x or bigger. No matter what this one is called the deck has issues that need to be addressed.
    Nevada IOS#1730
    Nevada Energy Auditor #30
    775-342-4767 www.homecsi.com
    Stephen McSpadden's Avatar
    Stephen McSpadden Guest
    You're right in that a supporting beam is typically significantly larger that the joist members that are being supported; typically a double 2x or a 4x or larger. It looks totally inadequate to me. A single 2x8 "beam" carrying a significant area of 2x8 joists typically will not qualify structurally. I recommend a structural engineers assessment. The installation sure is pretty but I have my doubts.
    While my terminology was not correct I certainly did blow the whistle on this deck.
    Oct 2009
    michigan
    If the beem is sized properly in the pic.... then it would suffice to say that the joyist's only need be 2x2's.
    Bob,
    Are we to presume you forgot the smiley face for your "beem" and "joyist's"
    James Duffin's Avatar
    James Duffin Guest
    The beam in the picture is no different than a 2x8 band board on a deck that the floor joist nail to. The main problem I see is the way the beam is attached to the post and a Simpson bracket would fix that for about $4. It looks like the beam is spanning about 4'.
    Some difference
    A band board a joist nailed to one side, where as the photo shows a joist nailed to each side of this beam, thus twice the load.
    Phil Brody's Avatar
    Phil Brody Guest
    It's a beam but definitely not a girder..
    i see more and more decks build with the support girder strataling 4x4 posts held together with nails or few lag bolts. sometimes the rim joist is nailed into a 4x4 with is also the railing post.
    my first comment is this deck never had a permit pulled. once i show the client that the deck is not resting on support columns, just nails i have their attention. I also explain that if it was proper why is the house center girder sitting squarely on a column? last if the deck is higher than i few feet i explain that 4x4 can bend and twist and 6x6's should be used.
    education is a wonderful thing.
    steve
    Anacortes, Washington
    If your are questioning whether the "beam" is sufficient for the load then you need to refer it out. Most homeowners do not get permits nor do the lower tier of contractors who are not good enough for remodels but can do decks.
    As has been said in previous posts on this board, go with your gut, if you don't think its right and the homeowner has no documentation to say that was permitted and a qualified contractor build it, then it needs to be evaluated by someone who is qualified.
    //Rick
    Rick Bunzel
    WWW.PacCrestInspections.com
    360-588-6956
    Sugarloaf, PA
    John, "Expected framing details not observed" covers a lot of ground ... then what Rick said. The language "confirm/establish to be blah blah" are sometimes helpful.
    Also, just my opinion here, I always comment on the work, not the work-er. IE, "Unworkmanlike ... blah blah ... observed"; "temporary blah blah observed", as opposed to "installed by and amateur, jackleg uncle bob should have his electrical tools confiscated in the interest of public safety ... installation observed" ... makes the point without overly insulting guilty party.
    "the relentless pursuit of perfection"
    Jan 2011
    Marietta, Georgia
    I, too, was always under the impression that a girder is built up and a beam is solid. In the IRC under beam/grider spans tables (section 502.5), it always lists the size of girders at 2-2xwhatever, 2-2x4s, 2-2x6's 2-2x8's ect. The span charts never list a single member as a girder...doesn't mean they don't exist, it just does not show single members as girders. Of course, the Code is not God and can never cover the infinite number of ways contractors or homeowners can screw something up and make us put our thinking caps on.
    Sep 2007
    Fredericksburg, VA
    Quote Originally Posted by Joseph Peake View Post
    How about, "Should have his air nailer taken away" I've used that one in a report on a pre-drywall inspection. I have wanted to say, "Who brought their 10 year old kid and his cub scout buddies to frame this house?".
    Ridgewood, NJ
    Joe, does the average person reading that know what it means?
    Sugarloaf, PA
    Hi Neil,
    I use that general comment to cover many bases and then I get specific. "joist hangers appeared to be undersized; ledger board did not appear to be properly attached to the structure; flashing not observed at ledger board etc... I also include comments to the effect "recommend consultation with a general contactor regarding repair/modifications/upgrades who is proficient in the specialized field of deck construction. Deck construction is frequently undertaken as a diy project by a person who would not even consider framing their own home due to an admitted lack of expertise; yet in many ways, decks are subject to more varied conditions than the interior framing of the home..."
    My thought is to alert the Client that "it's wrong", "give him a list of some of the wrong things" and he should get a qualified contrator to tell him how much it would cost "to make it right".
    Joe
    Contractor School OnlineĀ® - Contractor Glossary of Terms
    - Beam.A straight structural member that acts primarily to resist transverse loads; a structural element which sustains transverse loading and develops internal forces of bending and shear in resisting the loads; an inclusive term for joists, girders, rafters, and purlins.
    - Girder.A beam that supports other beams; a very large beam, especially one that is built up from smaller elements; a timber beam used to support wall beams or joists.
    And this:
    RSMeans?
    - beam(1) A horizontal structural member, such as a girder, rafter, or purlin, which transversely supports a load and transfers the load to vertical members, such as columns and walls. (2) The graduated horizontal bar of a weighing scale.
    - girderA large principal beam of steel, reinforced concrete, wood, or a combination of these, used to support other structural members at isolated points along its length.
