Results 1 to 3 of 3
08-27-2011, 06:22 AM #1
Proper way to measure Hearth Extenstion
Does any one know if the hearth extention on a masonary fireplace should be measured out from the "front " or "rear" of the facebrick? See photo.
Thanks.
08-27-2011, 06:34 AM #2
Re: Proper way to measure Hearth Extenstion
Front, the way you've got the tape. That hearth needs to be wider.
I've seen people lay a row of tiles across the front for a simple upgrade.
08-27-2011, 08:08 AM #3
Is that a raised foundation? If so, I believe there shouldnt be any wood below the hearth extension-check with Bob Harper, he'll know for sure.
Mazza Inspections and stuff...
https://mazzainspections.com
https://waterintrusionspecialist.com
