Results 1 to 3 of 3
Thread: What is this?
    M Kelekci's Avatar
    M Kelekci Guest
    Default What is this?
    What is this? It was found in a condo that was built in 1970 next to a receptacle.
    Default Re: What is this?
    Maybe a filler insert to adapt a duplex receptacle cover over to a hole for a cable for the TV?
    What did you see when you looked in the hole? You did look didn't you. Digital dilema. Too easy to take a pic. You should have looked.
    You would might either see a cable or a antennae hookup but I wasn't there
