Thread: And Stay In
02-10-2012, 02:32 PM #1
And Stay In
I hope none of the college girls living here will need to make a hasty exit from this place in the near future. And be sure to wear a helmet going in and out of that door.
Similar Threads:"It takes a big man to cry. It takes an even bigger man to laugh at that man". - Jack Handey
02-10-2012, 02:38 PM #2
Re: And Stay In
What's that chain attached to?
And, does the lid actually open while the "cage" door is closed?
02-10-2012, 03:30 PM #3
Re: And Stay In
The chain was attached to an eye bolt which was installed in the side of window well retaining wall. It appeared to have a carabiner type clip on the end but the basement level bedroom that provided access to the well was locked so I couldn't get to the window from inside to test it and see how/if the chain unhooked.
I'm not sure if the cage provided enough clearance. The grate may very well hit on the underside of the cage and go nowhere but I couldn't confirm it. Even if it can lift up, I could see the grate falling back down on somebody as they try to exit. Just a bad design all around. I told the buyer all somebody needs to do is jamb a stick, nail, screwdriver or something in the lock holes on the cages gate and nobody will be getting out. Temple U.
02-10-2012, 06:50 PM #4
Re: And Stay In
you need to stop those Philly Inspections.
(A third world city)
02-10-2012, 09:48 PM #5
Re: And Stay In
Escape thru the basement window seems to be impossible without an axe or a chainsaw. That's scary.
The emphasis seems to be more to keep the frat boys out, wouldn't you say?
