Results 1 to 3 of 3
    Mount Pleasant, SC
    Default AAV below the disposal drain
    Is this an issue that needs correcting?
    I think the AAV should be higher than the disposal drain exit. Someone else has a differing opinion.
    www.atozinspector.com
    Default Re: AAV below the disposal drain
    Oatey AAV height info:
    Must be installed no less than 4” above the center line of the highest trap arm served and not within 2 pipe diameters of a trap weir.
    http://www.google.com/url?sa=t&rct=j...crZeKQ&cad=rja
    Mount Pleasant, SC
    Thanks Dom,
    I'll be keeping the pdf source cited.
