Results 1 to 4 of 4
    Clyde Willett's Avatar
    Clyde Willett Guest
    Default Direct Vent Fireplace
    My question is concerning the terminology of mechanical air inlet. I have installed a direct vent gas fireplace and the instructions give specific distances for the termination cap to mechanical air inlets. My question is a bathroom exhaust fan a mechanical air inlet (I have installed a few of these in the past but have never had to deal with the tight spaces I am now). My common sense tells me that a inlet is differant from an exhaust.
    Clyde Willett Guest
    Default Re: Direct Vent Fireplace
    With 53 views I can only glean that most of the people here do not know the answer to the question I have put fourth.
    Quote Originally Posted by Clyde Willett View Post
    No a bathroom exhaust fan is not the same as a mechanical air inlet.
    With a direct vent FP you will have an air intake that can be part of the exhaust flue. You need to post the model number and brand you are dealing with. We have several fireplace specialist that visit this site that might be able to help if you provide them with some additional information.
    You have to follow the specific manufacturers requirements with fireplaces.
    Clyde Willett Guest
    Thanks Scott
