Results 1 to 3 of 3
    so so, California
    Default Direct/indirect venting question
    Regarding an up-flow high E furnace; Does the installer have the option of direct or indirect venting or does the manufacture typically dictate the manner in which the furnace is vented?
    The Furnace I inspected is indirect, however the combustion air is taken from the garage which sparked my interest, leading to this post.
    Marc
    Default Re: Direct/indirect venting question
    The furnace also appears to be IN the garage.
    As pictured it could not be considered direct vent. Sealed combustion chamber also required to be considered to be same.
    The manufacturer's instructions and recommendations which are part of the listing investigation, and the limitations of both the code(s) and the other equally important conditions of the space.
    I note in the same space (garage?) there appears to be a Cat I water heater (to the right). Thus the furnace would encourage backdrafting of the WH hood. And would be in conflict with provisions for alternative installation to DV.
    I also suspect (although not pictured) the likelyhood additonal appliances may be present - i.e. laundry (?).
    so so, California
    Excellent points, thanks HG.
