Thread: What is this?
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default What is this?
    Default Re: What is this?
    What is this electrical device connected to the plumbing line
    Probably either a solenoid controlled shut off valve or a circulating pump, I'm inclined to go with solenoid controlled shut off valve as it does not look like any circulating pumps I've seen.
    Jeff Eastman Guest
    hey thanks! so is the configuration okay?
    Not including anything else, but if you cannot get to the other side of it - NO!
    Jeff,
    Looks OK to me.
    It either cuts off water flow or boost water pressure.
    WHOOPS!!!
    Peter Plein's Avatar
    Peter Plein Guest
    That is a Honeywell motor actuated valve, usually used as a zone valve for hot water heat. The only ones I have ever seen are 24 volts.
    Jeff
    If that gypsum partition covering is the fire protection between the units it needs fire taping/sealing. Also, how does one access that electrical J-box?
